Y yeahman Getting the hang of it Nov 8, 2016 122 5 Dec 28, 2016 #1 Sometimes (quite often actually), I can't view recorded clips in the mobile android app. It does not play; empty blueiris app screen. I think that happens if BI is still recording (i.e. motion detection still occurring) Is it normal?
fenderman Staff member Mar 9, 2014 36,891 21,417 Dec 28, 2016 #2 yeahman said: Sometimes (quite often actually), I can't view recorded clips in the mobile android app. It does not play; empty blueiris app screen. I think that happens if BI is still recording (i.e. motion detection still occurring) Is it normal? Click to expand... its normal if you are recording to any format other than BVR. You should be recording to BVR, its most efficient and allows you to view a clip while its still open.
Y yeahman Getting the hang of it Nov 8, 2016 122 5 Dec 31, 2016 #3 i am recording with BVR and direct to disk. One thing I also notice, when viewing the latest clip on my pc, it very often freezes for 5-10seconds before displaying the clip
T tygger Getting the hang of it Aug 29, 2015 239 25 Dec 31, 2016 #4 So you're not actually missing any footage when you say it freezes 5-10 seconds before displaying a clip?
Y yeahman Getting the hang of it Nov 8, 2016 122 5 Dec 31, 2016 #5 no it just freezes .. I have to wait.. it's annoying
fenderman Staff member Mar 9, 2014 36,891 21,417 Dec 31, 2016 #6 Post a screenshot of your record tab setting... Also what is your CPU consumption
