Ctrl + C
xmtech # help
?       - alias for 'help'
base    - print or set address offset
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/
TFTP protocol
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
ddr     - ddr training function
fload   - fload  - load binary file from a filesystem image for system boot
flwrite - SPI flash sub-system
getinfo - print hardware information
go      - start application at address 'addr'
help    - print command description/usage
lip     - lip      - set local ip address but not save to flash
loadb   - load binary file over serial line (kermit mode)
loady   - load binary file over serial line (ymodem mode)
loop    - infinite loop on address range
mac     - mac      - set mac address and save to flash
md      - memory display
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mtest   - simple RAM read/write test
mw      - memory write (fill)
nm      - memory modify (constant address)
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
rarpboot- boot image via network using RARP/TFTP protocol
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv  - set environment variables
sf      - SPI flash sub-system
sip     - sip      - set server ip address but not save to flash
tftp    - tftp  - download or upload image via network using TFTP protocol
version - print monitor version
xmtech #
