- Jul 1, 2015
- 99
- 7
Hey all,
As you may know I have just connected 5 HIk cams to a Hik NVR. See thread here for teething troubles
Now that I have them up and running, its time for some fine-tuning. Setting up recording schedules, motion detection etc etc. So, I downloaded the User Guide for the IP cams and went through it all morning !
First things first.
Hardware:
5 x Hik DS-2CD2335-I firmware 5.3.3
NVR: Hik 7616NI E2/8P
Software
iVMS-4200 version 2.3.1.3
iVMS-4500 (iOS) version 4.2.2
I am currently accessing both the camera and NVR web GUI's via Firefox by changing my desktop's IP and subnet to be on same as of cams.
I can see that a lot of settings are available across both NVR and camera Configuration pages ... Mainly motion detection. I setup motion detection for one of the cams, but when I went to the NVR configuration page for motion detection, nothing was set-up there !
So, where should I set-up motion detection - individually in all cameras and/or NVR ?
Some other questions:
What does Record File Size mean ?
In what situation would I need PPoe or DDNS ?
Is it worthwhile to enable https for home environment. Has anyone done it ? Costs involved in certification etc ?
Does anyone use ezviz regularly ? How did you find it ?
ROI Region of Interest setting. Manual says 4 regions can be set. But cam web GUI shows only 1
Day/night scheduled switch
Do you set it to scheduled or auto ? Mine's currently set to Auto
Should HDD info be visible from camera configuration page (Advanced configuration > Storage > Storage Management) or only nvr
configuration page ? I have one 6TB HDD in NVR (WD Purple. Will be adding another 4TB soon. Toral of 10TB)
Pre-record and Post-record
I have set Pre-record interval to 30s and Post-record to 1m. Are these numbers OK ?
Why would I need event triggered snapshot, when I have full event triggered video and I can take snapshot from video ??
Where would I use SNMP ?
If you are up for it, here are some screenshots of the settings from CAMERA WEB GUI
First things first.
Hardware:
Software
