Hello, I have Dahua cameras installed at home, along with a Dahua NVR and a Dahua PoE switch. Recently, I added a new camera, and while all other cameras work perfectly, this last one is giving me trouble. I checked the cable with a tester, and it shows that the cable is fine. However, when I connect the camera, only the green PoE light on the switch turns on, while the red ACT light remains off. The camera was tested on a shorter cable directly connected to the PoE switch in the control room, and it worked without any issues. The camera is already configured. Has anyone encountered this issue before or can offer any advice? Thank you!
