SOLVED: CRAPPY WIRING OR MULTIPLE BAD CRIMPS? EITHER WAY I FINALLY GOT CONNECTION.
Hello all!
I'm at a standstill so I'm resorting to joining this wonderful forum
skipping to the issue:
Lorex system from costco. POE wired.
I currently have 3 cameras installed and running well.
2 indoors and 1 outdoors towards driveway.
Im currently installing the 2nd outdoor camera and the issue is I've ran the wiring from the nvr - to attic- to soffit area - to now outdoors. tested with the ethernet tool and all numbers 1-8 minus G light up stating connection is good. now! I plug in the wiring to the nvr and to the camera and i get no connection?
all ports tested on the nvr already good to go there, all cameras work even the one mentioned being installed. but for some odd reason im not getting connection around the attic??
I've made a piggyback ethernet cable to test all cameras and ports. 100% connection.
Zero connection with outdoors connection even tho the rj45 tester thing says its all good.
futhest cable runsabout 50ft from driveway to where my nvr is located.
this issue one is about 15ft going to nvr, attic, then outdoors thru a hole i made in the soffit.
Can anyone chime in on this issue? Thanks in advance.
Hello all!
