[solved] DS-KH6320-WTE1 can not connect 3 cameras
vantage
Mar 1, 2019
15
3
Wels
Hello,
i have a DS-7604NI-E1/4P/A (IP from this device is 192.168.1.130). I connect 3 cameras DS-2CD2142FWD-IS to this NVR via PoE Ports. So in this case, the 3 cameras geht the IP 192.168.254.2, 192.168.254.3 and 192.168.254.4. I can reach this cameras via webbrowser with 192.168.1.130:65001 / 65002 or 65003.
I have also the Indoor Staiton DS-KH6320-WTE1 with the IP 192.168.1.132.
So, my question is. How i can connect the three cameras which are connected to my NVR with my Indoor Station? What i have to configure?
Thank you.
vantage
Suggestion to try :
Change the mode of the NVR PoE channels to Manual instead of Plug&Play.
This is to stop the NVR changing the camera network settings back.
On the NVR PoE-connected cameras web GUI, change the default gateway to 192.168.254.1
Ensure Virtual Host is enabled on the NVR.
On your LAN router, add a static route, something like :
"For network 192.168.254.0/24 (ie subnet mask 255.255.255.0) use <NVR_LAN_interface_IP_address ie 192.168.1.130> as gateway"
When you've done that - confirm that you can reach the NVR PoE-connected cameras directly on their actual IP addresses ie 192.168.254.2 etc
Then see if the DoorStation can also reach the cameras directly on their actual IP addresses..
