Hi Everyone,
I'm following this forum for quite some time and it has really great content that helped me many times before.
This time, however it's the first time I wasn't able to find a solution to my problem - I'm not able to make the Dahua VTO3211D doorbell to call the indoor screen VTH5321GW-W.
I've successfully connected VTO3211D and VTH5321GW-W and I'm able to make a call from the VTH5321GW-W to the VTO3211D, however for some reason when I ring the doorbell on VTO3211D it won't activate the call on the internal screen (DHI-VTH5321GW-W). The doorbell states that the call is being initiated however the DHI-VTH5321GW-W doesn't even lit up.
This is the firmware I'm running on the VTO and the VTH:
VTO and VTH are both Online:
VTO basic properties:
VTO Household Settings:
Network settings:
VTO SIP settings:
VTH is also successfully connected to SIP server on the VTO:
VTH Network Config:
VTH SIP Config:
VTH VTO Config:
VTH VTO Available and working:
I've reconfigured both the VTH and the VTO many times, restarted both devices and I can't seem to figure out why the SIP connection is established from VTH -> VTO but not VTO -> VTH.
If anyone has any ideas and would be willing to share them, you'd be really helping me out a lot.
Thanks in advance and best regards!
Network settings:
VTO SIP settings:
VTH Network Config:
VTH SIP Config:
VTH VTO Config:
