Any solar guru's on here , trying to setup a remote solar powered ip cameras with ptp .
Problems I am having with setup , will be using locom2 for ptp which is 24v passive , x2 ip cams with are 48volt 802.3A/F , A poe Swicth which can be powered poe but has different outputs ,have attached two drawings of two setup components , is there an easy way in doing this .
Have found this solar poe switch which does the work of 4 things (wI-PS306GF-UPS-V2) but only one company sells them here in Australia . Thanks for any info
