Tried searching but got many links to off grid stuff. Are they any decent network cams that are solar powered so I don't have to run power or network to them?
If you plan to run the camera 24x7 you will need a larger solar panel and battery setup. Most likely you would need to assemble this yourself from component parts.
The typical consumer solar powered cameras are designed for motion detection activate video capture
