DouglasteR Young grasshopper Nov 15, 2015 52 14 Oct 18, 2016 #1 Hi there my friends. I have inherited an ip camera with the "label" KE-HDC232-POE and i cant find its ip address. I have tried some ip config tools but to no avail. Anyone knows any software to hear the broadcasts or other methods ? Thanks.
zero-degrees Known around here Aug 15, 2015 1,335 845 Oct 18, 2016 #2 DouglasteR said: Hi there my friends. I have inherited an ip camera with the "label" KE-HDC232-POE and i cant find its ip address. I have tried some ip config tools but to no avail. Anyone knows any software to hear the broadcasts or other methods ? Thanks. Click to expand... Go grab ONVIF device manager https://sourceforge.net/projects/onvifdm/ Reactions: DouglasteR
zero-degrees Known around here Aug 15, 2015 1,335 845 Oct 18, 2016 #3 You can also try Advanced IP Scanner. http://www.advanced-ip-scanner.com/ Main thing with a lot of tools is assuring you are at least on the same network as the camera (192.x.x.x or 10.x.x.x. etc). If the camera has DHCP enabled no problem, but that is very rare since you want static ip's for cameras.
DouglasteR Young grasshopper Nov 15, 2015 52 14 Oct 18, 2016 #4 Wow ! ONVIF scanner did it ! Thank you so much !
