Hi all.
This is a short review about this camera
Low price (150$)
PTZ (optical zoom)
I was quite afraid to buy this item but, for those who saw my expectations, I was looking for :
- solar powered camera (12V + low consumption)
- 4G connection only
- correct quality
- PTZ if possible
I tried it and ... it works !
Picture quality is very surprising (above all, you can select higher quality if you want, I choose the lowest quality for speed and try to see difference at a few times)
For consumption (12V5) the maximum power is less than 10W (when it start)
Normal connection cause about 3W consumption witch is very low I think for camera + 4G (day, no IR)
Negative points ? sometime it doesn't connect to my phone, I have to try again.
But , as I tried about 10 connections in a complete day to see what happen, I never need to restart camera which is a good point (in a few days, camera will be far away, about 250km).
Camera can send alarms too. It's seems to detect movement correctly (middle sensivity)
So my conclusion:
A good choice for a low price (and picture quality, and PTZ and ....)
Low price (150$)
PTZ (optical zoom)
- correct quality
- PTZ if possible
	So my conclusion:
