So glad I found this group!
Sep 30, 2019
2
Ridgecrest Ca
Hello everyone! I'm looking to get a security camera setup and I'm blown by all the options out there. The cameras would be for my house, probably need 4, and I would like to be able to remotely monitor and get notifications through an app. So far I'm thinking a wired system that uses Poe cables and a nvr box with about 1tb of memory. There are so many brands out there. Can you guys direct me towards some good brands. Thank you so much.
:welcome:
Welcome to the forum.
Please read my welcome post below, it is a good starting place.
You can you an NVR or Blue Iris. Blue iris is PC based, it is recommend that it be on a standalone PC.
If you are going the NVR route use that same brand as you cameras.
Read,study,plan before spending money ..... plan plan plan
My standard welcome to the forum message.
Please read the cliff notes and other items in the wiki. The wiki is in the blue bar at the top of the page.
Read How to Secure Your Network (Don't Get Hacked!) | IP Cam Talk in the wiki also.
Quick start
1) Use Dahua starlight cameras or Hikvision darkfighter cameras or ICPT Night eye cameras (https://store.ipcamtalk.com/) if you need good low light cameras.
2) use a VPN to access home network (openVPN)
3) Do not use wifi cameras.
4) Do not use cloud storage
5) Do Not use uPNP, P2P, QR, do not open ports,
6) More megapixel is not necessarily better.
7) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
8) Do not use reolink, ring, nest cameras (they are junk)
9) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
10) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
11) use a test mount to verify the camera mount location. My test rig: rev.2
12) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 8ft. You want to know who did it, not just what happened.
13) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
14) camera placement use the calculator... IPVM Camera Calculator V3
Cameras to look at
IPC-HDW2231R-ZS Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW5231-ZE Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE IPC-HFW4239T-ASE
IPC-T5442TM-AS Review IPC-T5442TM-AS-LED (Full Color, Starlight+)
IPCT-HDW5431RE-I Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
DS-2CD2325FWD-I
IPC-T5442TM-AS Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A https://ipcamtalk.com/threads/review-dahua-ipc-k35a-3mp-cube-camera.37581/#post-373517
Test do not guess
if you are interested in Dahua cameras, a forum member sells dahua and ships world wide. You can read some of the members recommendations on his service. He also provides cameras to other forum member for evaluation and reviews.
you can email him for a quote, or purchase from his Aliexpress store or his Amazon store.
Andy
@EMPIRETECANDY
[email protected]
http://s.click.aliexpress.com/e/sOuNHLIs
https://www.amazon.com/s?tag=ipctk-...VPDKIKX0DER&redirect=true&slotNum=0&ref=as_at
:welcome:
Quick start
Cameras to look at
DS-2CD2325FWD-I
DS-2CD2442FWD-IW
IPC-K35A Review-Dahua IPC-K35A 3mp Cube Camera
Test do not guess
Andy
@EMPIRETECANDY
[email protected]
Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group
Kingsecurity2018 @ Amazon.com:
Thank you for the info!
