i am trying to retrieve the snapshot using the REST API call:It was added to an update after substreams where introduced:
From the help file.
5.3.3 - October 1, 2020
When using dual-streaming, JPEG images will be created from the main-stream instead of
the sub-stream where possible. Rather than fully spooling up main-stream decoding, the
software uses the direct-to-disc pre-trigger frames buffer to synthesize these images. This
means you should specify at least enough pre-trigger time on the Record tab to span the
key-frame interval for your main-stream.
And yes, the issue of the clone camera without the substreams then makes it not a clone and motion detection will be made from the mainstream then and then you are pulling two video streams and actually using more CPU.
Code:
/image/{cam-short-name}
Still getting the substream version of the snapshot. Any ideas if it is even possible to obtain the highres version?
