Snapshot and email pic hourly for an 8 hour period?
larry1302
May 10, 2015
12
12
Can Blue Iris be configured to take a snapshot of a camera hourly, say between the hours of 8:00 and 16:00 and email it immediately?
Remote location, only internet available is behind a double NAT, first nat is from ISP, no option to avoid it. Only way I have found thru it is with a canary cam or a PC running teamviewer to access cameras, wife would like some daily pics via text.
Fenderman:
Could you explain how to setup such a configuration? I have had Blue Iris running for several years simply in a motion record config but am a novice when it comes to a config such as this. Thank you.
Larry
The easiest way to do it is to setup an email alert on trigger, then use camera properties>schedule>event schedule to trigger an alert at the times you want.
