I have them all blank and still get the detected by deepstackTry Camera / Alerts / On Alert / your SMS alert then:
Then I change my answer to ...." I don't know"!I have them all blank and still get the detected by deepstack
I like the object and % just wanted to eliminate the deepstack part. No big dealThe detected by DeepStack is I believe backed into BI. Not sure if we can eliminate that portion?
I have been meaning to try this but haven't got around to it yet LOL is does it disappear if you remove the Burn in option? I would assume you simply get the alert image without the rectangle, but the %text would still be there.
Thanks, guess my lazy ass should have tried that alreadyInstead of leaving it blank, use &MEMO in the text field and you'll get the object and % without "detected by deepstack" part. Just tried it and it worked.
It seems with some simple PERL or other script code we can easily parse the Deepstack response into an array split by comma, then : (or () etc).
So I just don't see it as super pressing, but it's on my very-extended to-do list.
- Ken
