paulsalcedo n3wb Jun 10, 2024 6 0 Philippines Jun 10, 2024 #1 Everytime I will enable the SMD On the settings it keeps saying reached max capability of AI analysis. Is there anyone who's able to turn on all the SMD on 8 cameras? My cam model is DH-XVR1B08-I
bigredfish IPCT+ Member Sep 5, 2016 32,870 79,876 The Swamp Jun 10, 2024 #2 That is your NVR Model number. What are your camera models and are they all HDCVI or are you using IP cameras? That NVR is very low end and only supports 4 channels SMD by recorder.
paulsalcedo n3wb Jun 10, 2024 6 0 Philippines Jun 10, 2024 #3 bigredfish said: That is your NVR Model number. What are your camera models and are they all HDCVI or are you using IP cameras? That NVR is very low end and only supports 4 channels SMD by recorder. Click to expand... HDCVI
paulsalcedo n3wb Jun 10, 2024 6 0 Philippines Jun 10, 2024 #4 Is there new model that is high end to my present dvr?
bigredfish IPCT+ Member Sep 5, 2016 32,870 79,876 The Swamp Jun 10, 2024 #5 Yes, MANY HDCVI Recorders - Dahua International HDCVI Recorders www.dahuasecurity.com This is yours https://www.dahuasecurity.com/asset/upload/uploads/cpq/prm-os-srv-res/smart/datasheetzipfiles/XVR1B08-I_datasheet_20220507.pdf
paulsalcedo n3wb Jun 10, 2024 6 0 Philippines Jun 10, 2024 #6 bigredfish said: Yes, MANY HDCVI Recorders - Dahua International HDCVI Recorders www.dahuasecurity.com This is yours https://www.dahuasecurity.com/asset/upload/uploads/cpq/prm-os-srv-res/smart/datasheetzipfiles/XVR1B08-I_datasheet_20220507.pdf Click to expand... Thanks! I found out that DH-XVR1B08-I only supports 4 channels for SMD
bigredfish IPCT+ Member Sep 5, 2016 32,870 79,876 The Swamp Jun 10, 2024 #7 Yes I detailed that in your other thread Reactions: paulsalcedo
paulsalcedo n3wb Jun 10, 2024 6 0 Philippines Jun 10, 2024 #8 T bigredfish said: Yes I detailed that in your other thread Click to expand... Thanks mate! Hopefully more people with the same problem will find this thread.
