I have a QNAP NAS and setup some tests doing continuous recording from some DS-2CD2385G1-I cameras. I tried NFS and had no luck. Every time no matter the volume size/quota I would get uninitialized status under HDD Management.
I'm able to get SMB/CIFS to work but have noticed it will only uses 1 HDD. (separate folder and user ID/quota) The first one setup is all that is used. I thought maybe it would spill to the next after the first HDD/quota filled but that does not seam to be the case.
As for volume size I have one that was 1024gb and it appears to be working although I'm not sure how well as it's only been a day.
I was hoping to setup a large volume for each of like 1TB and let it record continuously but I'm not sure what all quirks there are to this setup. I found some old links but I'm not sure they still apply.
Any words of wisdom?
