Hello,
I finally got IVS working with dahua cameras and the NVR-4232 4K.
Unfortunately I can't see IVS recordings in the SmartPSS. The NVR does definitely record, I can see the recordings on the playback list directly on the NVR.
in SmartPSS under Playback in the lower right corner you can select the type of recording to search. "All" ist preselected. The dropdown shows all other types, general alarm motion.... but no IVS (all colors except for orange here).
I first thought taht I should use an older Version of the software (since I had to make an downgrade on the NVR to get IVS support). That didn't solve my problem.
Strange thing: Whenn I add a camera as device (not the complete NVR with its devices) and pull this camera on the Liveview grid, I can make a rightclick on the stream end get a submenu with en IVS entry. But when I select the streams from the NVR there ist no IVS entry.
So: SmartPSS can list all recordings on the NVR except for IVS recordings although they are existent. And: SmartPSS does seem to support IVS but not from the NVR.
Am I getting something wrong?
Greetings
Alex
Greetings
Alex
