Hi guys. First off I wasnt sure where to post this but anyways, is there another software other than smartpss to view my NVRs. It would be great if the software could also use P2P to remote access the NVRs as well.
SmartPSS can do P2P, other than that, you can login to the NVR webpage, which is the best option.
IF you have p2p setup in smartpss, When in SmartPSS, go to the Device config tab, highlight the NVR you want to access, then click on LInk To Web at top of the page.
But, P2p is a security risk, you should be using OpenVpn for remote access. How to Secure Your Network (Don't Get Hacked!) | IP Cam Talk
