Hello,
For the moment I have the following configuration:
Two cameras:
- DS-7608NXI-I2/4S (firmware: V4.1.18build 200120), so with AcuSense.
All the settings are made on the NVR web interface.
Everything is working fine: motion detection, line crossing, intrusion...
But when I check the "Enable Smart Analysis" in the Smart Events tab, I can configure a line but nothing happens after. There are no events in the log and there are also no blue lines on the image (it is the case when I configure a line without the smart analysis). It is exactly the same with the instrusion area. I need the smart analysis for the human detection.
Do you have any idea of the problem?
Two cameras:
- DS-2CD2045FWD-I (firmware: V5.6.3build 190923) - Recording in H.265 2688x1520
- DS-2CD2145FWD-I (firmware: V5.6.2build 190701) - Same recording parameters
