Today I received my PFB203W wallmounts and noticed there was only one side where you can insert your UTP cable (see pics below). In my opinion Dahua could make a small adjustment so you can use both sides. I can mount one cam directly to the wall so the UTP cable is invisible behind the mount. For the other cam the UTP cable comes from te left side. Do I have to drill a small hole by myself or can I turn the whole mount upside down so my cam is on top of the bracket instead of hanging underneath?
