Hi I could really use some help if anyone would be kind enough. I need a system asap but I don't know what I should order.
My problem is I have slow DSL (2 mbps download, 1 mbps upload) but I would like to get motion alerts and be able to remote view from a cell phone since I live far pretty from town.
I live in the mountains on acreage and I could really benefit from some long runs of cable so I thought about buying a Dahua XVR so I could use both coax (long runs) and Ethernet cameras (short runs).
I would like a thermal camera or two for watching the elk at night and for trespassers / poachers and these only seem to be available for IP cameras. (XVR)
Here are my concerns:
Will I be able to remote view and get alerts with my crappy internet?
is there anything unreliable about an XVR or using both ethernet and coax? it seems that Power Over Coax hasn't had all the bugs worked out so I guess I would have to run a power wire with it for the long runs.
Is there another type of system that works with slow internet better? Someone mentioned Ubiquti saying that they have their own connection for remote areas but I can't find any info suggesting how this would work it seems like basic wireless is needed.
If I cant back up my stuff offsite using the internet I guess I am going to have to weld up a safe room in the barn to protect my NVR from getting stolen by a potential Thief (knock on wood). Is this my best and only option?
I am hoping to buy 16 camara system starting with 4 turrets, 1 ptr, 1 long distance bullet, 2 thermals, 1 XVR,DVR/NVR,
Any info and or suggestions would be greatly appreciated so I could get the ball rolling. Thank you
