Looking for ideas to troubleshoot a very slow frame rate when accessing the camera from WAN. LAN access works ok. I have set it up in BI and iDMSS and can access the camera from the internet, but I'm only getting .5 frames per second.
Forwarded the following ports
HTTP : 8081
RTSP : 8091
TCP: 37777
UDP 37778
I have another camera on the same router (Netgear N600) that gives a good frame rate.
I've forwarded these ports for it
HTTP: 8080
RTSP: 8090
I've tried lowering the frame rate of the Dahua to 10 and lowering the bit rate. Nothing helps. If I log onto the camera thru HTTP, I get an initial live video and it never updates again.
The camera is in my second home (I'm not there now) so the only access I have is thru the router or a direct HTTP connection.
Any ideas?
Thanks
Dan
HTTP : 8081
RTSP : 8091
TCP: 37777
UDP 37778
HTTP: 8080
RTSP: 8090
Any ideas?
Thanks
Dan
