- Dec 2, 2015
- 719
- 251
I am trying to figure out what could be causing a slow connection to an NVR from within the network on both wifi and via ethernet. I have ruled out double nat..
It is a hikvision system The NVR is ds-7616ni-e2/16p, 8 cameras are connected to the back of the NVR the other 7 cameras are connected to a switch with one cable running into one of the POE ports in the back of the NVR.
Couple questions:
1: Should the POE switch be connected to the back of the NVR or the local network router? or does it matter?
2: I noticed the NVR has a IP in the range of the local network ( something like 17.x.x.x.x ) but the cameras are using 198.x.x.x.x ips? Could this be the issue?
any suggestions??
Couple questions:
any suggestions??
