Sky Cams
Ri22o
2,264
4,529
Indiana
I decided to move the conversation from my other thread to here since I think this section is more appropriate.
After the meteorite explosion from the other day I am looking to have a couple cameras to monitor the skies.
I am currently using a spare 4K-T, but am thinking this might be overkill?
  • Is this model preferred because of its low light abilities?
  • Do I need to record in 4K or is 4MP more than sufficient?
  • Would I be equally served with a 5442?
  • Is there any reason to record during the day? (dumb question, I know...)
Here are my current settings:
Is this what most others see who do this? I am assuming the lighted clouds are transferring light pollution from the city that is over that way, even though the sky looks completely dark to the regular eye? Wrong or right, I am just surprised how well it picks up color and the little bit of light coming through the clouds.
You always want to record in native resolution as a downrez could be a mess.
The 5442 is probably ok but since you have a spare 4K/T it lets in so much more light.
Of course you want to record it during the day so you catch things like a plane engine on fire:
Reactions: JDreaming
I'm only using the 4K-T because I have it and haven't found a real position for it yet, but didn't know if I would be better/worse with a different model when/if I commit cams to full time use for this.
I sort of figured day time recording to be the case for that, which is why I thought it to be a dumb question, haha.
I am just trying to not kill my storage with something frivolous like this because it's taking up a lot (5gb per hour of footage). When I add more views for 360 coverage it will chew up even more and take away from the things I actually want to be able to review.
I may need to make some adjustments if this is going to be used during the day, the sun is not helping.
You will probably have to make a day profile and drop gain and brightness way down and force a fast shutter.
What about using an AUX folder and just store the skycam video for a few days?
is it possible to create a Time lapse from an existing clip or no?
I suppose that's a possibility. I just need to see how large it would be so I know how long I want to keep all of it.
