Hi, I have a Hikvision NVR with several cameras connected and have been using IVMS-4200 with the NVR. I wanted to use Blue Iris to view my cameras because I like the interface and the way the program works.
I installed Blue Iris and connected my NVR without a problem.
My problem is this, the cameras come on when I start Blue Iris but they will be on for only 10 seconds then the live stream stops and then it will say Signal Loss. It goes a few seconds then it will connect again and go live for another 10 seconds and it will repeat this cycle over and over again.
I connected a separate camera on my network without using the NVR and the camera stays live and does not lose the signal.
Does anybody know what would cause the Blue Iris to lose the signal and then come back on, go live then have a signal loss and keep cycling through when using this program? This does not happen with IVMS-4200 program. Is there something that needs to be set with either the NVR or Blue Iris?
Thanks for your help.
