J JFire Getting the hang of it Aug 26, 2015 406 40 Pittsburgh, PA Mar 17, 2017 #1 Has anyone tried this? I have firesticks galore and am thinking this is the cheapest way to have all of my tvs able to view the cameras? Sent from my SM-G928T using Tapatalk
J JFire Getting the hang of it Aug 26, 2015 406 40 Pittsburgh, PA Mar 17, 2017 #2 Well i answered my own question. Yes you can and it loads but no way to control the interface. Sent from my SM-G928T using Tapatalk
nayr IPCT Contributor Jul 16, 2014 9,229 5,330 Denver, CO Mar 17, 2017 #3 use TinyCam Pro, works well on a TV
J JFire Getting the hang of it Aug 26, 2015 406 40 Pittsburgh, PA Mar 17, 2017 #4 nayr said: use TinyCam Pro, works well on a TV Click to expand... Trying to use it. I dont think it likes poe nvr. I plug in the ip address and it only bring up camera 1. Sent from my SM-G928T using Tapatalk
nayr IPCT Contributor Jul 16, 2014 9,229 5,330 Denver, CO Mar 17, 2017 #5 change the channel in settings Reactions: looney2ns
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,226 Evansville, In. USA Mar 17, 2017 #6 JFire said: Trying to use it. I dont think it likes poe nvr. I plug in the ip address and it only bring up camera 1. Sent from my SM-G928T using Tapatalk Click to expand... Copy the settings from the one camera that works, then past it to add another cam. Leave everything the same, except the channel number. Rinse and repeat for each channel. Reactions: nayr
