Would it be best to run two Cat6 cables from a PoE switch to provide power for a camera and IR Illuminator which are going to be at the same location? I could use one to directly connect to the RJ45 connection on the camera and the other to an active PoE power over ethernet splitter that would provide the 12v barrel connection and power to the IR Illuminator.
Is there an easier way than this that wouldn't consume two PoE switch ports? Thanks
