Hello All,
Last night after arriving home form work there where a number of shots fired within 60 feet of my residence. The Police arrived and asked if they can view the footage of my cameras. My cameras have served me well thus far but from time to time because I have them set for motion detection the footage can jump from one instance to another if the subjects are not very active in the field of view. As in this footage you can see two men walk by, loiter around and then the footage jumps to seeing them practically out of the field of view running away. Because of the lack of motion the cameras did not pick up the instance of the gunshots. When I configured the cameras in Blue Iris, I set them for max sensitivity. Although these types of instances are rare, I would really like to be able to have my cameras pick up the entire event. I would like some suggestions / help on what I should do to be able to have a complete storyline for at least a couple of my cameras that I feel are pointed at locations that may be "higher risk areas". Or re-configure them some what where they are not "Choppy". Should I just purchase a bigger hard drive specifically for continual recording? How big a terabyte drive would I need? Is this problem with the configuration of the internal software of the camera or the settings in Blue Iris? Is multiple hard drives good to have dedicated for specific cameras? Allot of questions I know but if I was able to have caught the event in full, The more the Police would of had to work with.
Thank you for any help you can offer.
Paul
Paul
(plus look at the blur on the face and he is barely moving and this should be ideal indoor IR bounce and it struggles):
