At first sorry for by bad english, i will try to explain as good as i can
I am using Hikvision for many years, generally satisfied, but there are some issues i face , time by time. Maybe i am missing something, or dont know, so i will post it, and see if i am the only one or not
- First. When i want to download a file on remote by web i cannot chose a specific time so lets say 20 oct from 01.00 till 01.15 ( whatever i do, it shows around 1 gb of file, and much more hours in timeplay. Sure i can download, later clip, merge convert etc ( and meanwhile get some virus by looking for a good converter ) I know another option is to make smaller packages, but i dont want that. On Gui interface however it is possible to only export a specific time of the day
- Second is that it is not possible to LOCK files on remote. So lets say i have to download clips from a nvr on another location, but on that moment my internet speed is slow, its not possible to lock, in order to download it another time. ( also on Gui interface it is possible )
Are you guys familair with this? Is there a workaround, or maybe newer firmware which supports this ?
