My cams are 2532 iws. 5.20 firmware hacked and not yet MTD'd because I am still running behind on stuff.
I have ssh enabled in cam firmware
Using Linux (Kubuntu)
I haven't been able access the recordings on the sd card. If I set it to record on NAS all is fine. All files are there even with time-stamps.
How can I FTP or SFTP into the SD-card to download files?
I understand why they don't want you to access root directory. Is there a way to access only the sd card? Like for example, is there a special user defined which would have access only to SD?
Thank you.
Thank you.
