Setup Wyze v3 to BI
patrocle
Pulling my weight
Jun 5, 2015
541
130
California
Just curious if anyone here setup a wyze v3 into BI?
As i know they do not have any rstp firmware out yet for them.
Thanks,
I have not found anything. They want to sell you their cloud storage.
the V2 has a version of firmware that works, just don't ask for much.
A decent Amcrest camera is not much more, and a lot better picture and features.
The V3 has problems at might with motion blur.
Reactions: patrocle
Yes, their cloud. I have a v2 in BI, just to test it out but looks that v3 no have option to add in BI.
Will normally i don't want wifi cams, and i know cable is better, but i need a cam for my garden and the only way to put one is wifi. I have some sidewalks and can not put a wire under neat.
Maybe an access point with ethernet plug to connect a amcrest ip cam may work?
Thanks,
Wyze says V3 RTSP Firmware is in the works but no additional information is available. So.. no idea when it will come out. Until then only V2 works with RTSP.
Reactions: Old Timer
