Hello,
I have purchased a Safire intercom (Hikvision OEM): SF-VI112-IPW-2MF
identical to Hikvision DS-KV8213-WME1
I am in a two-family house where two Gira G1 are installed. They are used for controlling the smart home and as indoor stations for the intercom.
Now I am unsuccessfully trying to set up the Sip configuration.
The whole thing should work without a Sip server
When button one is pressed, sip:192.168.1.23 should be called.
When pressing the second key, the second internal station should be called, e.g. sip:192.168.1.24.
The two internal stations should be able to call the external station (sip:192.168.1.111).
I can't find a way to make this work with the intercom. I can't find a setting for the DTMF codes to open the door.
The Sip-function on the indoor stations is workong well. E.g. with microsip.
In the meantime I have loaded the original firmware from Hikvision onto the Intercom.
This firmware seems to be identical to the Safire firmware.
Can someone please help me?
Thank you!
Thank you!
