Setup Question
ServiceXp
Feb 12, 2015
214
18
USA
So here is the situation. I need to know how to get this working.
The goal: To have all of the camera's bandwidth on a separate network, but still have access to the internet. All using the WS2012E Machine
Current Infrastructure:
1) WS2012E Server with a 4 port Intel Nic Card installed.
2) Router and switch in another area of building. (One CAT6 going to server - (No easy way to get an additional cable from the switch to Server))
3) POE switch for camera's located right next to Server.
4) 6 POE Camera's
My Options:
TIA
If you are running all cameras to your POE switch then all you have to do is plug it into a 2nd Ethernet or NIC card using a different ip range than your other network.
