- Jul 2, 2017
- 118
- 14
Got the walk through on here and setup the ntp with nettime. Question, is the ntp server address on my nvr going to be the ip address of the computer running nettime?
Check to see if your network properties changed to "public" from "private" or vice versa. Updates to W10 does it sometimes, W11 probably does it too.Did you get this working? What OS do you have running NetTime ? I updated my BI PC and it's running Win11 with NetTime and it won't accept any time sync requests even with Windows firewall off. I had it running with no issues on the old BI pc running Win7.
So it's the "public ipcam lan" and cams won't update time from PC running Nettime?I have two NICs, the onboard which is my main lan is private and the second which is my ipcam lan is public.
Possibly....wish I could offer more helpThe ipcam lan is also listed as "unidentified" but I assume that is because it has no internet access and/or gateway?
