Setup Hikvision/LTS on BI Port settings for BI and Camera
nutshellml
Jun 22, 2016
195
15
So I had my 5 Hikvision/LTS cameras set up for a while as I was testing everything. I now moved want to make sure I have them 100% as they are on my standalone computer. Few areas of confusion:
I have the CMIP3042 for example, I've noticed some moderate ghosting. I have set the fps to 20 on BI and have put the Receive buffer to 20MB. On my camera the Max BR is 6144, I Frame Interval 50 (what is that exactly) and SVC - OFF. The ports on my camera are http 8096 rtsp 555 https 443 server 8001. I'm not sure what to put for ONVIF/Discover, I have 8096, is that correct? Because I notice that when I go back to the main Video tab in BI the network ip shows xxxxxx:80
Any thoughts?
Any thoughts?
you need to match the iframe interval to the fps and set windows to high performance.
Thanks, and I'm correct with my port configuration? The ports on my camera are http 8096 rtsp 555 https 443 server 8001. I'm not sure what to put for ONVIF/Discover, I have 8096, is that correct?
if you are getting video the ports are correct..
