MikeLud1
The older 5241 was closer to the 5231. My neighbor has a 5241 from one of the firsts batches and you cannot tell the difference between his 5241 and my 5231.
The newer Z12s use a different chipset than the previous ones and the settings on my recent one I got are completely different from my older 5231-Z12 or neighbors 5241-Z12 settings (that are using my identical 5231 settings).
There are differences in the hardware/chipset between an older 5241-Z12 and a newer 5241-Z12 - probably a result of chip vendor changes. My 5241 has a build date of October 2020. My neighbors 5241-Z12 had a build date of October 2019. The settings are completely different between the two looking at the same spot. I set his up and had placed it next to mine to see if there were any differences.
