All,
I'm making a system that will eventually be used on small residential construction sites. We'll use a cellular modem, and Verizon 4G service.
Today, I'm eliminating the P2P connection method (too many drawbacks). Instead, I'll use a VPN. I'll use port forwarding to reach the NVR that's connected to the Cradlepoint cellular modem.
Problem 1) Verizon issues a private IP address to my cellular modem. The public IP is quite different.
Solution 1) The VPN connection should take care of this, I hope.
My plan: Use a free hosted vpn service on the internet eg: totalVPN.com
That should maintain the vpn tunnel through Verizon and back to my cellular modem (which has vpn capabilities)
This should solve the private/public ip address translation from the Verizon NAT.
When we want to surf in to the Job Site NVR, we'll surf to the hosted VPN, which will connect us through Verizon to the cellular modem, and finally, the job site NVR.
Today's first step is to set up the VPN on my wired network, using my Comcast connection. Thankfully, Comcast issues public IPs
After the VPN is working on the wired system (using Comcast), then hopefully I can use the VPN through Verizon....
It will be a long day - if you see any pitfalls with me plan, plz speak up! I'll post notes on progress & findings!
Thanks,
Fastb
Thanks,
Fastb
