I'm a camera newb and I currently have a Reolink recording with BlueIris aimed at my driveway since I live a bit off the beaten path. The performance is lackluster. I've been lurking on the forum trying to find a replacement and there are so many options. I am looking for an IP POE camera that has good low light performance and records audio via the network, not a separate cable (if that's a thing). My driveway is about 150ft long although I've only been recording if someone actually enters the driveway, not when every car passes by. I'm willing to spend more money to get better performance although I'm not sure what that range really looks like.
I like the BlueIris setup although long term I may decide to get a device that will just continuously record. I've run the ethernet for 4 more cameras so far but wanted to experiment with 1 or 2 to make sure I'm getting the performance I want before buying the wrong parts.
I have found the IPC-T5442T-ZE mentioned repeatedly as a benchmark so that's where I am currently. Any other models or considerations?
Thanks!
Thanks!
