After reading the pros/cons on installing BI on a VM, i've decided to build it dedicated box for the system, since I have a 2U server case that will be perfect to run BI in.
Here are the specs for this system:
Skylake i7 6700K CPU
Gigabyte GA-H110M-A LGA 1151 mATX
8GB DDR4 RAM
256GB Crucial SSD (from a former build)
I know some will say that its a waste having the 6700K CPU with a non-overclockable board, but I am not overclocking so its a moot point as stock speed is good enough.
What I want to do is after the system is built I plan to put the 2U chassis in the server rack. Is it possible to view the video streams on a monitor away from the rack since this system will be running headless? Say for example the server will be downstairs and I will be upstairs in my studio working and would like to view the video streams from the studio, while giving the opportunity to remote in to the system should I need to make any changes to the software. This will be on a home wired LAN network.
I thought of maybe installing BI on my Server 2012 R2 Essentials machine (no VM) which has 16GB RAM on a Xeon E3 1230-V2 but since I have the skylake hardware may as well put it to use. I plan to use Windows 8.1 Pro for the OS (not touching Win10 at this time).
As of now I don't have any cameras to test yet, as I need to get perhaps one or two to test, along with needing a POE switch to connect them to. But I would like to get the PC side of the hardware ready so all I would have to do is connect and run once I get the cameras and switch. I also have an extra PCIe Intel dual NIC at my disposal too.
Any help would be great!
8GB DDR4 RAM
