One of the reasons I've been installing Dahua firmware on various Lorex-branded IP cameras is to be able to set the i-frame interval in the Video config page. the Lorex GUI hides this and defaults to 2x the frame rate (FPS), which isn't a horrible setting, but some of us want/need to adjust that for whatever reason.
turns out that that tho the UI is dumbed down, the underlying (Dahua) API still mostly works, so one can use commands to set things the GUI may not present, like I-frame interval (called GOP in the API):
for example, this gets you the current configuration:
and on my Lorex E891ab, this returns the following:
then this URL will SET the gop (for the main pulled rtsp stream) to 15 (was 30)
And this persists across camera powercycling! sweet. This may come as obvious to those who've previosuly used the Dahua HTTP API, but nice to know it can (apparently) be applied to the Lorex (and maybe Amcrest?) rebrands as well. Not a panacea for these rebrands limitations, but may be useful in specific cases, like that of the missing 'iframe interval' configurable...
edit: google the API, or poke around here for links to it... "Dahua IPC HTTP API"
table.Encode[0].ExtraFormat[0].Audio.Bitrate=64
table.Encode[0].ExtraFormat[0].Audio.Channels[0]=0
table.Encode[0].ExtraFormat[0].Audio.Compression=AAC
table.Encode[0].ExtraFormat[0].Audio.Depth=16
table.Encode[0].ExtraFormat[0].Audio.Frequency=8000
table.Encode[0].ExtraFormat[0].Audio.Pack=DHAV
table.Encode[0].ExtraFormat[0].AudioEnable=false
table.Encode[0].ExtraFormat[0].Video.resolution=704x480
table.Encode[0].ExtraFormat[0].Video.BitRate=256
table.Encode[0].ExtraFormat[0].Video.BitRateControl=CBR
table.Encode[0].ExtraFormat[0].Video.Compression=H.264
table.Encode[0].ExtraFormat[0].Video.CustomResolutionName=D1
table.Encode[0].ExtraFormat[0].Video.FPS=15
table.Encode[0].ExtraFormat[0].Video.GOP=15
table.Encode[0].ExtraFormat[0].Video.Height=480
table.Encode[0].ExtraFormat[0].Video.Pack=DHAV
table.Encode[0].ExtraFormat[0].Video.Priority=0
table.Encode[0].ExtraFormat[0].Video.Profile=High
table.Encode[0].ExtraFormat[0].Video.Quality=4
table.Encode[0].ExtraFormat[0].Video.QualityRange=6
table.Encode[0].ExtraFormat[0].Video.SVCTLayer=1
table.Encode[0].ExtraFormat[0].Video.Width=704
table.Encode[0].ExtraFormat[0].VideoEnable=true
table.Encode[0].ExtraFormat[1].Audio.Bitrate=64
table.Encode[0].ExtraFormat[1].Audio.Channels[0]=0
table.Encode[0].ExtraFormat[1].Audio.Compression=AAC
table.Encode[0].ExtraFormat[1].Audio.Depth=16
table.Encode[0].ExtraFormat[1].Audio.Frequency=8000
table.Encode[0].ExtraFormat[1].Audio.Pack=DHAV
table.Encode[0].ExtraFormat[1].AudioEnable=false
table.Encode[0].ExtraFormat[1].Video.resolution=704x480
table.Encode[0].ExtraFormat[1].Video.BitRate=1024
table.Encode[0].ExtraFormat[1].Video.BitRateControl=CBR
table.Encode[0].ExtraFormat[1].Video.Compression=H.264
table.Encode[0].ExtraFormat[1].Video.CustomResolutionName=D1
table.Encode[0].ExtraFormat[1].Video.FPS=30
table.Encode[0].ExtraFormat[1].Video.GOP=60
table.Encode[0].ExtraFormat[1].Video.Height=480
table.Encode[0].ExtraFormat[1].Video.Pack=DHAV
table.Encode[0].ExtraFormat[1].Video.Priority=0
table.Encode[0].ExtraFormat[1].Video.Profile=High
table.Encode[0].ExtraFormat[1].Video.Quality=4
table.Encode[0].ExtraFormat[1].Video.QualityRange=6
table.Encode[0].ExtraFormat[1].Video.SVCTLayer=1
table.Encode[0].ExtraFormat[1].Video.Width=704
table.Encode[0].ExtraFormat[1].VideoEnable=false
table.Encode[0].ExtraFormat[2].Audio.Bitrate=64
table.Encode[0].ExtraFormat[2].Audio.Channels[0]=0
table.Encode[0].ExtraFormat[2].Audio.Compression=AAC
table.Encode[0].ExtraFormat[2].Audio.Depth=16
table.Encode[0].ExtraFormat[2].Audio.Frequency=8000
table.Encode[0].ExtraFormat[2].Audio.Pack=DHAV
table.Encode[0].ExtraFormat[2].AudioEnable=false
table.Encode[0].ExtraFormat[2].Video.resolution=704x480
table.Encode[0].ExtraFormat[2].Video.BitRate=1024
table.Encode[0].ExtraFormat[2].Video.BitRateControl=CBR
table.Encode[0].ExtraFormat[2].Video.Compression=H.264
table.Encode[0].ExtraFormat[2].Video.CustomResolutionName=D1
table.Encode[0].ExtraFormat[2].Video.FPS=30
table.Encode[0].ExtraFormat[2].Video.GOP=60
table.Encode[0].ExtraFormat[2].Video.Height=480
table.Encode[0].ExtraFormat[2].Video.Pack=DHAV
table.Encode[0].ExtraFormat[2].Video.Priority=0
table.Encode[0].ExtraFormat[2].Video.Profile=High
table.Encode[0].ExtraFormat[2].Video.Quality=4
table.Encode[0].ExtraFormat[2].Video.QualityRange=6
table.Encode[0].ExtraFormat[2].Video.SVCTLayer=1
table.Encode[0].ExtraFormat[2].Video.Width=704
table.Encode[0].ExtraFormat[2].VideoEnable=false
table.Encode[0].MainFormat[0].Audio.Bitrate=64
table.Encode[0].MainFormat[0].Audio.Channels[0]=0
table.Encode[0].MainFormat[0].Audio.Compression=AAC
table.Encode[0].MainFormat[0].Audio.Depth=16
table.Encode[0].MainFormat[0].Audio.Frequency=8000
table.Encode[0].MainFormat[0].Audio.Mode=0
table.Encode[0].MainFormat[0].Audio.Pack=DHAV
table.Encode[0].MainFormat[0].AudioEnable=false
table.Encode[0].MainFormat[0].Video.resolution=3840x2160
table.Encode[0].MainFormat[0].Video.BitRate=4096
table.Encode[0].MainFormat[0].Video.BitRateControl=CBR
table.Encode[0].MainFormat[0].Video.Compression=H.264
table.Encode[0].MainFormat[0].Video.CustomResolutionName=3840x2160
table.Encode[0].MainFormat[0].Video.FPS=15
table.Encode[0].MainFormat[0].Video.GOP=30
table.Encode[0].MainFormat[0].Video.Height=2160
table.Encode[0].MainFormat[0].Video.Pack=DHAV
table.Encode[0].MainFormat[0].Video.Priority=0
table.Encode[0].MainFormat[0].Video.Profile=Main
table.Encode[0].MainFormat[0].Video.Quality=4
table.Encode[0].MainFormat[0].Video.QualityRange=6
table.Encode[0].MainFormat[0].Video.SVCTLayer=1
table.Encode[0].MainFormat[0].Video.Width=3840
table.Encode[0].MainFormat[0].VideoEnable=true
table.Encode[0].MainFormat[1].Audio.Bitrate=64
table.Encode[0].MainFormat[1].Audio.Channels[0]=0
table.Encode[0].MainFormat[1].Audio.Compression=AAC
table.Encode[0].MainFormat[1].Audio.Depth=16
table.Encode[0].MainFormat[1].Audio.Frequency=8000
table.Encode[0].MainFormat[1].Audio.Mode=0
table.Encode[0].MainFormat[1].Audio.Pack=DHAV
table.Encode[0].MainFormat[1].AudioEnable=false
table.Encode[0].MainFormat[1].Video.resolution=3840x2160
table.Encode[0].MainFormat[1].Video.BitRate=4096
table.Encode[0].MainFormat[1].Video.BitRateControl=CBR
table.Encode[0].MainFormat[1].Video.Compression=H.264
table.Encode[0].MainFormat[1].Video.CustomResolutionName=3840x2160
table.Encode[0].MainFormat[1].Video.FPS=15
table.Encode[0].MainFormat[1].Video.GOP=30
table.Encode[0].MainFormat[1].Video.Height=2160
table.Encode[0].MainFormat[1].Video.Pack=DHAV
table.Encode[0].MainFormat[1].Video.Priority=0
table.Encode[0].MainFormat[1].Video.Profile=Main
table.Encode[0].MainFormat[1].Video.Quality=4
table.Encode[0].MainFormat[1].Video.QualityRange=6
table.Encode[0].MainFormat[1].Video.SVCTLayer=1
table.Encode[0].MainFormat[1].Video.Width=3840
table.Encode[0].MainFormat[1].VideoEnable=true
table.Encode[0].MainFormat[2].Audio.Bitrate=64
table.Encode[0].MainFormat[2].Audio.Channels[0]=0
table.Encode[0].MainFormat[2].Audio.Compression=AAC
table.Encode[0].MainFormat[2].Audio.Depth=16
table.Encode[0].MainFormat[2].Audio.Frequency=8000
table.Encode[0].MainFormat[2].Audio.Mode=0
table.Encode[0].MainFormat[2].Audio.Pack=DHAV
table.Encode[0].MainFormat[2].AudioEnable=false
table.Encode[0].MainFormat[2].Video.resolution=3840x2160
table.Encode[0].MainFormat[2].Video.BitRate=4096
table.Encode[0].MainFormat[2].Video.BitRateControl=CBR
table.Encode[0].MainFormat[2].Video.Compression=H.264
table.Encode[0].MainFormat[2].Video.CustomResolutionName=3840x2160
table.Encode[0].MainFormat[2].Video.FPS=15
table.Encode[0].MainFormat[2].Video.GOP=30
table.Encode[0].MainFormat[2].Video.Height=2160
table.Encode[0].MainFormat[2].Video.Pack=DHAV
table.Encode[0].MainFormat[2].Video.Priority=0
table.Encode[0].MainFormat[2].Video.Profile=Main
table.Encode[0].MainFormat[2].Video.Quality=4
table.Encode[0].MainFormat[2].Video.QualityRange=6
table.Encode[0].MainFormat[2].Video.SVCTLayer=1
table.Encode[0].MainFormat[2].Video.Width=3840
table.Encode[0].MainFormat[2].VideoEnable=true
table.Encode[0].MainFormat[3].Audio.Bitrate=64
table.Encode[0].MainFormat[3].Audio.Channels[0]=0
table.Encode[0].MainFormat[3].Audio.Compression=AAC
table.Encode[0].MainFormat[3].Audio.Depth=16
table.Encode[0].MainFormat[3].Audio.Frequency=8000
table.Encode[0].MainFormat[3].Audio.Mode=0
table.Encode[0].MainFormat[3].Audio.Pack=DHAV
table.Encode[0].MainFormat[3].AudioEnable=false
table.Encode[0].MainFormat[3].Video.resolution=1280x720
table.Encode[0].MainFormat[3].Video.BitRate=1024
table.Encode[0].MainFormat[3].Video.BitRateControl=CBR
table.Encode[0].MainFormat[3].Video.Compression=H.264
table.Encode[0].MainFormat[3].Video.CustomResolutionName=720P
table.Encode[0].MainFormat[3].Video.FPS=15
table.Encode[0].MainFormat[3].Video.GOP=30
table.Encode[0].MainFormat[3].Video.Height=720
table.Encode[0].MainFormat[3].Video.Pack=DHAV
table.Encode[0].MainFormat[3].Video.Priority=0
table.Encode[0].MainFormat[3].Video.Profile=High
table.Encode[0].MainFormat[3].Video.Quality=4
table.Encode[0].MainFormat[3].Video.QualityRange=6
table.Encode[0].MainFormat[3].Video.SVCTLayer=1
table.Encode[0].MainFormat[3].Video.Width=1280
table.Encode[0].MainFormat[3].VideoEnable=true
table.Encode[0].SnapFormat[0].Audio.Bitrate=64
table.Encode[0].SnapFormat[0].Audio.Compression=G.711A
table.Encode[0].SnapFormat[0].Audio.Depth=16
table.Encode[0].SnapFormat[0].Audio.Frequency=8000
table.Encode[0].SnapFormat[0].Audio.Pack=DHAV
table.Encode[0].SnapFormat[0].AudioEnable=false
table.Encode[0].SnapFormat[0].Video.resolution=3840x2160
table.Encode[0].SnapFormat[0].Video.BitRate=5120
table.Encode[0].SnapFormat[0].Video.BitRateControl=VBR
table.Encode[0].SnapFormat[0].Video.Compression=MJPG
table.Encode[0].SnapFormat[0].Video.CustomResolutionName=3840x2160
table.Encode[0].SnapFormat[0].Video.FPS=0.100000
table.Encode[0].SnapFormat[0].Video.GOP=60
table.Encode[0].SnapFormat[0].Video.Height=2160
table.Encode[0].SnapFormat[0].Video.Pack=DHAV
table.Encode[0].SnapFormat[0].Video.Priority=0
table.Encode[0].SnapFormat[0].Video.Profile=Main
table.Encode[0].SnapFormat[0].Video.Quality=5
table.Encode[0].SnapFormat[0].Video.QualityRange=6
table.Encode[0].SnapFormat[0].Video.SVCTLayer=1
table.Encode[0].SnapFormat[0].Video.Width=3840
table.Encode[0].SnapFormat[0].VideoEnable=true
table.Encode[0].SnapFormat[1].Audio.Bitrate=64
table.Encode[0].SnapFormat[1].Audio.Compression=G.711A
table.Encode[0].SnapFormat[1].Audio.Depth=16
table.Encode[0].SnapFormat[1].Audio.Frequency=8000
table.Encode[0].SnapFormat[1].Audio.Pack=DHAV
table.Encode[0].SnapFormat[1].AudioEnable=false
table.Encode[0].SnapFormat[1].Video.resolution=3840x2160
table.Encode[0].SnapFormat[1].Video.BitRate=5120
table.Encode[0].SnapFormat[1].Video.BitRateControl=VBR
table.Encode[0].SnapFormat[1].Video.Compression=MJPG
table.Encode[0].SnapFormat[1].Video.CustomResolutionName=3840x2160
table.Encode[0].SnapFormat[1].Video.FPS=0.100000
table.Encode[0].SnapFormat[1].Video.GOP=60
table.Encode[0].SnapFormat[1].Video.Height=2160
table.Encode[0].SnapFormat[1].Video.Pack=DHAV
table.Encode[0].SnapFormat[1].Video.Priority=0
table.Encode[0].SnapFormat[1].Video.Profile=Main
table.Encode[0].SnapFormat[1].Video.Quality=5
table.Encode[0].SnapFormat[1].Video.QualityRange=6
table.Encode[0].SnapFormat[1].Video.SVCTLayer=1
table.Encode[0].SnapFormat[1].Video.Width=3840
table.Encode[0].SnapFormat[1].VideoEnable=true
table.Encode[0].SnapFormat[2].Audio.Bitrate=64
table.Encode[0].SnapFormat[2].Audio.Compression=G.711A
table.Encode[0].SnapFormat[2].Audio.Depth=16
table.Encode[0].SnapFormat[2].Audio.Frequency=8000
table.Encode[0].SnapFormat[2].Audio.Pack=DHAV
table.Encode[0].SnapFormat[2].AudioEnable=false
table.Encode[0].SnapFormat[2].Video.resolution=3840x2160
table.Encode[0].SnapFormat[2].Video.BitRate=5120
table.Encode[0].SnapFormat[2].Video.BitRateControl=VBR
table.Encode[0].SnapFormat[2].Video.Compression=MJPG
table.Encode[0].SnapFormat[2].Video.CustomResolutionName=3840x2160
table.Encode[0].SnapFormat[2].Video.FPS=0.100000
table.Encode[0].SnapFormat[2].Video.GOP=60
table.Encode[0].SnapFormat[2].Video.Height=2160
table.Encode[0].SnapFormat[2].Video.Pack=DHAV
table.Encode[0].SnapFormat[2].Video.Priority=0
table.Encode[0].SnapFormat[2].Video.Profile=Main
table.Encode[0].SnapFormat[2].Video.Quality=5
table.Encode[0].SnapFormat[2].Video.QualityRange=6
table.Encode[0].SnapFormat[2].Video.SVCTLayer=1
table.Encode[0].SnapFormat[2].Video.Width=3840
table.Encode[0].SnapFormat[2].VideoEnable=true
http://192.168.0.73/cgi-bin/configManager.cgi?action=setConfig&Encode[0].ExtraFormat[0].Video.GOP=15
