Yes, it is my understanding that the 60GHz connection is much more fragile than a 5GHz connection, so the 5 GHz takes over in case the 60 GHz goes offline. Rain has a much stronger effect on 60GHz signals.
He said he coudln't find any in stock. My job isn't to sniff out the best price. I responded with a location they were in stock.LOL 4 times the normal price. You guys are crazy if you over pay that much. For that price he could buy the high end models that are in stock at UI.
Limited-time deal: TP-Link AC1750 Smart WiFi Router (Archer A7) -Dual Band Gigabit Wireless Internet Router for Home, Works with Alexa, VPN Server, Parental Control, QoS
This should work well
It’s only $57 and it’s a TPLink
