Bubs Getting comfortable Dec 26, 2016 84 21 Feb 1, 2017 #1 Has anyone used self sealing silicone tape to seal/waterproof ethernet connections
nayr IPCT Contributor Jul 16, 2014 9,229 5,330 Denver, CO Feb 1, 2017 #2 yes, its highly recommended.. if not mandatory in some situations. Reactions: hmjgriffon
Bubs Getting comfortable Dec 26, 2016 84 21 Feb 1, 2017 #3 Thank for quick response as I'm new to IP cams so I'm trying to learn at first I was going to use the old standby electric tape,(decided against this) so is down heat shrink tap and Silicone tape, is seam to me silicone tape is more versatile
looney2ns IPCT Contributor Sep 25, 2016 16,752 24,980 Evansville, In. USA Feb 2, 2017 #4 Doesn't hurt to add a touch of Di-electric grease to the connection as well.
Q™ IPCT Contributor Feb 16, 2015 4,939 3,988 Megatroplis, USA Feb 2, 2017 #5 Amazon.com: Universal Electronics Original # 104 Coax Seal Hand Moldable Plastic Weather Seal: Home Audio & Theater As an Amazon Associate IPCamTalk earns from qualifying purchases.
P phydeaux Getting the hang of it Jul 6, 2016 54 48 Feb 3, 2017 #6 I prefer Butyl over silicone for exterior electrical sealing
