I don't actually know, sorry, as I'm running it on a 7816N-E2 that has no PoE ports. I'm leaving my 7816N-E2/8P pretty much alone in terms of updates as its my 'production system'.1. Does the 3.3.4 come with virtual host?
I haven't seen any quirks or problems on the web GUI, it's stable and been on it about 2 weeks just to see how it is.2. How are you finding it with respect to software bugs etc.
Until I take the time to tune down the motion events in the cameras, I won't be using email alerts as I'd be swamped.3. Does the motion email attached photos of the motion event?
If you place your NVR on the same switch as the cameras you will accomplish the same thing without the noise of the built in poe ports and direct access to the cameras as well as not having to homerun the cameras to the NVR.
1) using a fanless poe switch.1. In this setup, how will you power the IP cameras?
2. How loud is the noise from built-in POE ports or is this coming from the fan of the NVR?
2) yes its coming from the fan..
Hikvision made some vertical NVR's sold by lts that had much larger fans and were much quieter...
1) yes. Except I think there is still a fan on the non-poe NVR's...I havent seen the newer hikvision non poe nvr's...It should be quieter though...1. I see. So from the router, you connect a fanless poe switch. From this fanless poe switch, you connect a fanless NVR and each IP camera?
2. Would using the Hikvision NVR's built-in POE consume more power than say, using a DC adapter for each IP camera?
