Hi all,
Made some compromises with locations and camera types when I first set up my system a couple of years back. I have a mix of Amcrest and Dahua 2.7 (variable)/2.8 (fixed) mm IR "turret" style POE cameras, 4 and 5 MP resolution.
Looking for some camera recommendations which can give me a wider or broader view of some of the areas outside of my home. I know there is a need to balance the ability to monitor vs. identify, but I'm feeling I don't have enough of the perimeter of the house covered and wish to shift a couple of the cameras to improve monitoring.
Looking for some recommendations for cameras I should consider that would meet the following requirements:
Thanks in advance!
- Wider field of view
- Local network only
- Synology Surveillance Station compatibility
- Ideally match the PFA130-E junction box without modifications
- IR is a must due to low light conditions
- Ideally priced $200-300
Thanks in advance!
