Thanks, guys. Appreciate your feedback. Going to stick with my original plan. Need to get going on the install as winter is coming!
Hi Guys - Didn't want to start a new thread so thought I'd follow-up with a few questions here (if you don't mind!).
1 - How do you access the PC hosting BI? Do you go headless and RDP to the machine when needed? Or do you buy a cheap monitor/keyboard to manage directly?
2 - Do most of you put BI, cams, etc. on their own LAN/VLAN so cameras can't 'phone home'?
3 - Are there any shortcuts to planning camera location? I know where I'll put them, but guessing how high I want them is trial and error? Run a long CAT from the rack and plug in the camera and just hold it in place during the day/night and take a look via BI to make sure it looks good? If it does, then fish the CAT to the mount location? Just curious if there's tips / shortcuts? I read the wiki and camera install forum but didn't find anything definitive. If you know of a helpful thread / wiki page I may have missed, would appreciate a link!
Which Villa Door station, there is more than one.
See my reviews on Villa stations and doorbells.
Many of us run headless and RDP in when needed.
Most put the cams on VLAN or Dual NIC (easier and cheaper)
Best thing to do is to temp rig (a bucket with rocks and a 2x4 or 4x4 works well) them at the various locations to make sure day/night you capture what you want and don't get weird reflective glare from a house light, lamp post, IR bounce off of the house or shrubs, etc. Generally try to keep below 8 feet.
So what we have done is take an old wifi router and put the wifi doorbell or indoor wifi camera on it. All that is on that router are the cameras and nothing else. You then also do not connect it to the internet. Instead you connect it to the camera POE switch. That is much safer than letting it on your LAN router with internet access.
