I have a second home that I'd like to set up an NVR system (inside and outside cams). Looks like Hikvision 7608 NI E2 8P is a good choice. I have control 4 in the home for lights/door locks etc. There are some NVR's that integrate with C4 but I'm not sure I need the integration.
Is there another system I should look at?
Does the Hikvision work well viewed remotely on a Mac?
Thanks for you pre-purchase advice.
Scott
Scott
