On a Amcrest 1179 with the exposure set to a range for the shutter speed and gain, is there any way to see what the current shutter speed and gain the camera is using within that range?
By frame rate, I think he meant shutter speed not FPS and bitrate.
I believe he is asking for what number is the shutter speed and what number is the gain for a particular scene if you have put a range in for shutter and gain.
Assuming a camera is set to 15 FPS, if shutter speed is changed to 1/3 sec, Tinycam reports 3 FPS for the camera. I just tested it. Maybe this is really just an academic exercise...You set the FPS in the camera and it doesn't change based on the other parameters.
It is only on cheap cloud-based and other consumer crap cameras (like Reolink) that FPS will change based on conditions.
Look how many of us use Blue Iris with a KEY of 1.00 which means the FPS and iframes are the same number. It is only the cheap cameras where we see FPS dancing around.
