Hello all. New member here.
I have recently installed a security camera under the eave of my home. I didn't think it would matter that it was placed about half a metre and in front of an existing light sensor switch for some security lights. You can guess that it did.
Anyway, the security lights started coming on for no apparent reason. I found that If I switched off the camera the security lights went back to normal. I even covered up the "eye" of the sensor with duct tape but they still came on.
A little googling tells me that the sensor is picking up the heat from the camera and causing the lights to switch on. I believe the sensor picks up infrared heat. I am guessing that infrared must be able to penetrate the duct tape, so the lights kept coming on even when the sensor was covered.
It was quite an effort for me to install the camera. I am 71 years old and there were times when I was crawling through the roof cavity/taking off roof sheeting that I thought I was going to croak. I don't want to go through much of that again.
My question is this: I can move the camera back behind and to the side of the sensor (about 300 mm) but will the sensor still pick up the heat from behind it? The sensor is only supposed to have a 180 degree field in front of it.
This is a similar sensor switch
Here are some photos.
