Hey guys,
Looking to see if there is an equivalent to an outdoor Nest cam, but with local storage. I am trying to weigh my options and right now the NEST outdoor cams seem like a great option. Their mobile app is pretty much second to none and worth the 80 dollars a year alone. So the cam must be WIFI, and externally powered as I have wall outlets outside. I would love to do POE, however I have a split level with a sub basement and it would be an absolute nightmare to drop cat6. Cams should be 180 degree, 4k or even 1080p that have good sensors. Should also have night vision and can work with a built machine with blue iris or even a standalone NVR. Looking for something that will also have a good UI experience, especially for mobile and can alert when motion is detected. It would be nice to have some of the additional options, like geofencing, facial recognition, etc, but not required. As far as what I want to spend, probably under 700, just need two cams. Looking to add an indoor cam as well if budget allows.
Let me know what you would do.
Thanks in advance.
Thanks in advance.
